U4GM Tips BO7 Best Scorestreaks for Fast Points and Kills
Pour suggérer des améliorations pour le forum ou le site ou tout simplement pour faire des remarques.
Messagede Andrew736 » Jeu 5 Fév 2026 08:44
After a week of getting tossed around in Black Ops 7, you start to notice something: the "best" player isn't always the one stacking gunfights. It's the one who's always got a streak in the air, always squeezing points out of the system. If you're trying to level fast or just want cleaner reps, some people even buy CoD BO7 Bot Lobbies for sale so they can focus on dialing in routes and streak timing without the usual chaos. Either way, BO7 rewards efficiency, and the economy game is where matches get flipped.
Start Small, Print Points
The most consistent core I've used is UAV into Counter-UAV. Not because it's flashy, but because it pays you back. UAV gives you the obvious value: reads, pre-aims, quicker rotations. Counter-UAV is where the scoreboard starts to tilt, because people panic when the minimap goes dark and they take dumb fights. While it's up, you're basically farming cleaner kills, quicker trades, and a steady drip of assist score from teammates doing the same. Don't chase the "dream" streaks first. Get the engine running, then let it carry you.
The Cheap Spike That Saves Bad Lives
Hand Cannon is the cheat code nobody wants to admit they rely on. At 800 points it's not some heroic flex, it's a practical reset button. You spawn in, you're down tempo, your team's getting pinched—pull it out and take back a lane in two shots. On cramped maps it's borderline rude, especially when you use it to break a hill or stop a push that would've snowballed. The trick is to treat it like a tool, not a highlight. Pop it, solve the problem, go back to building your next UAV cycle.
Turn Momentum Into Map Control
Once you're chaining the low streaks without thinking, that's when the mid-to-high stuff actually makes sense. HKDs (Mini-RAPS) are brutal for objectives because they don't just get kills—they make people stop looking at the point. Players get blinded, they shoot at the wrong thing, they back up into bad angles. Then, if the lobby's going long and you've kept your deaths low, saving for the D.A.W.G. feels like cashing out. On bigger layouts it soaks explosives, hunts stragglers, and forces the other team to waste time solving it instead of playing the mode.
Perks That Keep The Whole Loop Alive
None of this is consistent without perks built for streak math. Bankroll changes the first minute of every life; that early cushion means your opening gunfight isn't the only way to get moving. Dispatcher is the other half, because it makes those "almost there" moments happen more often. You stay alive, you call in UAV and Counter-UAV once, and suddenly your points don't feel tight anymore—they feel inevitable. And if you want an easier path to that rhythm, here's the split truth: as a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy u4gm CoD BO7 Bot Lobby for a better experience.
Andrew736
Retourner vers Suggestions, dysfonctionnements
