Victoire Cycles - Veloce - Columbus XCR
Messagede elfuinha » Lun 28 Nov 2016 16:15
Acording with Victoire Cycles - this will be probably the only Columbus XCR Veloce, that will be made this year, because tubing is very rare to get.
Waiting for an year, but for what i'm seeing it will be worth it.
http://cloud.tapatalk.com/s/57dc4d2c18892/victoire-nuno-1611.jpg?
http://cloud.tapatalk.com/s/57dc4d1cce256/victoire-nuno-1624.jpg?
http://cloud.tapatalk.com/s/57dc4d2894eab/victoire-nuno-1621.jpg?
http://cloud.tapatalk.com/s/57dc4d3425303/victoire-nuno-1619.jpg?
http://cloud.tapatalk.com/s/57dc4d4e16ee3/victoire-nuno-1620.jpg?
http://cloud.tapatalk.com/s/57dc4d5ee6f80/victoire-nuno-1618.jpg?
http://cloud.tapatalk.com/s/57dc4d74efb41/victoire-nuno-1617.jpg?
http://cloud.tapatalk.com/s/57dc4d6f6127a/victoire-nuno-1616.jpg?
http://cloud.tapatalk.com/s/57dc4d81b2333/victoire-nuno-1615.jpg?
http://cloud.tapatalk.com/s/57dc4d9b6539f/victoire-nuno-1612.jpg?
Painted!!!!
Painted!!!!
final Pictures of the Frame:
http://weightweenies.starbike.com/forum/download/file.php?id=63440&mode=view
Victoire Cycles Frame
THM Carbones CT2
Chris King Inset 7
EE brakes 2016 with pads
FD - Sram ETAP
RD - Sram ETAP
Shifthers - Sram ETAP
Saddle - Fizik Aliante 00
SeatPost - MCFK 20mm offset 31.6mm -
Lizard Skins 3,2 mm DSP
Cranks - Sworks 2017 - 175mm
Chainrings - Red ETAP 52/36
BB - Enduro XD-15 Torqtite
pedals - Keywin Carbon Ti
KMC DLC 11 - SL Black chain
K-edge chain catcher
K-edge Pionner Mount
MCFK Headcap
Arundel mandible 3k matte
Handlebar - MCFK
Stem MCFK
Lighweight Meilenstein 20/20
Veloflex Carbon/Arenberg
KCNC Z6 Qr's
Campagnolo 11-25
7004kg
Victoire Veloce XCR - 7,15kg (2016)
Moots Vamoots RSL - 6,20kg (2011)
Litespeed lookout Mtn - 8,40kg (2003)
elfuinha
Re: Victoire Cycles - Veloce - Columbus XCR
Messagede seb@bes » Lun 28 Nov 2016 18:25
Hi very nice build very light components also even if total is above 7kg.
Please may you disclose more about frameset :
- tubing specifications with diameter (if you know colombus ref is better)
- some geometry dimensions
- weight
So far I understand that you chose :
- 44mm headtube
- PF30 bottom bracket ?
- 34.9 (internal = 31.6) seat tube
Elfuihna, I do not remember your body characteristics.
I am asking because if 34.9 seattube and oversize bottom bracket, your frameset will be on the stiffest side of bottom.
The downtube diameter if 38 will be final locking features...but Victoire is often choosing smaller diameter to increase easiness.
Then you need to be very tall, strong and powerful to benefit all qualities of SSR XCR I think.
Thanks for sharing ;)
seb@bes
Messagede Tuut » Lun 28 Nov 2016 18:30
Pour moi le downtube fait 34;9 aussi ;)
Comme le seat tube
je le trouve très sobre et réussi ce vélo ;)
elfuinha ton lien sur weight weenies
renvoie vers une photo du pédalier s works monté à la place du OMC
pas sur le sujet complet
j'ai vu que tu avais eu des soucis de dérailleur avant ETAP :) C'est pour le résoudre que tu as mis un pédalier s works ou pas ?
ça fait un certains temps qu'il est monté car je te suis sur weight weenies ,
tu ne l'as pas encore roulé ?
Tuut
Messagede Marcassin » Lun 28 Nov 2016 19:27
Congrats man, that stainless rig looks so slick. What does the scale say about the frame?
Marcassin
Messagede elfuinha » Lun 28 Nov 2016 19:47
Tuut a écrit:Pour moi le downtube fait 34;9 aussi ;)
Comme le seat tube
Works great now.
Fonctionne très bien maintenant.
elfuinha
Messagede elfuinha » Lun 28 Nov 2016 19:53
seb@bes a écrit:Hi very nice build very light components also even if total is above 7kg.
- weight
- 44mm headtube
XCRL11600W - Toptube - 31,7mm
XCRA12670Z - Downtube - 38mm
XCRM13650A - Seattube - 33mm - internal 31.6mm
XCR114OV410001 - Chainstays
XCR615560 - seatstays
Costum "LocoMachine" - headtube
Paragon Dropouts
Paragon PFBB30
Internal rear brake cable. and Di2 ready.
elfuinha
Messagede Tuut » Lun 28 Nov 2016 20:03
je trouve ca pas cohérent le top tube plus fin que le tube de selle
ca me choque chaque fois que je vois ca
je peux comprendre que le but est de fixer la boite de pédalier etc
mais je préféré avoir un peu de flex du tube de selle que du TT
Tuut
Messagede elfuinha » Lun 28 Nov 2016 20:20
This bike is more comfortable than my Moots RSL. But it's stiffer on the front triangle.
about the seattube, i weight 83kg... so i tink 27,2mm is way to flexible.
Ce vélo est plus confortable que mon Moots RSL. Mais il est plus rigide sur le triangle avant.
Sur le siège, i poids 83kg ... donc je tink 27,2mm est la manière de flexible.
elfuinha
Messagede phill35 » Lun 28 Nov 2016 21:06
Connaissait pas cette marque de pedale ?!?
Keywin...
Sportif de bas niveau
phill35
Messagede taupe » Lun 28 Nov 2016 22:57
what's that crank and chainrings? They don't really look like a set of sworks/etap rings... ;-)
http://topwheels.fr
Messagede Tuut » Lun 28 Nov 2016 23:05
OMC
pédalier italien plateaux aussi
super rigide , genre hollowgram sisl2
pas très commun
il a eu des soucis de derailleur avant mais je sais pas si c'est pour ca qu'il a changé de pédalier
Tuut
Messagede elfuinha » Mar 29 Nov 2016 01:52
Tuut a écrit:OMC
pas très commun
OMC - http://veloptimal.com/forum/viewtopic.php?f=5&t=57313
SWORKS 2017 - http://weightweenies.starbike.com/forum/download/file.php?id=63440&mode=view
SRAM ETAP FONCTIONNE AVEC LES CHAINRINGS SRAM
elfuinha
Messagede seb@bes » Mar 29 Nov 2016 07:46
Paragon Dropouts
Paragon PFBB30
Many thanks my friend ! it is more clear for me, I appreciate your answer. My frameset full classic (bsa, 1''1/8, only rear brake internal) weights 1500g, sizes 51.
Now @80kg I can understand stiffer (or stiffest) design.
Because @70kg (and below) I chose to keep 31.8 seat tube and 27.2 seat post ; when I compared my friend's bike with XCRM13650 33mm, its bottom bracket is more locked and then his bike is a little bit less forgiving and less nervous (elasticity of bottom is minimized) especially in climbs. BUT very important difference compared to you, we sticked to BSA ! I can not imagine how far your frame shall be stiff. PF30 is good for titanium but SS might be too stiff...it depends absolutely on the rider. It seems you deserve more stiffness than both of us :D
Also my friend and I selected the most oversized front triangle from Colombus with same tubes as yours : 38mm and 31.8mm. Handling and power transmission is superb especially under torque. But main benefit from SS compared to titanium I feel is that you play with velocity pedalling without losing efficiency.
Have good rides !
seb@bes
Messagede elfuinha » Mar 29 Nov 2016 15:19
Paragon Dropouts
Paragon PFBB30
Have good rides !
Yes i wanted a Stiffer frame, but i still think that this frame is more comfortable than my Moots Vamoots RSL.
thanks for your comments.
elfuinha
Messagede pacou » Mar 20 Déc 2016 10:57
pacou
Messagede Man Of Steel » Mar 20 Déc 2016 12:42
Ils font des vélos chez Victoire...? je pensais qu'ils ne faisaient que de la com... :mrgreen:
Man Of Steel
Messagede vib » Mar 20 Déc 2016 12:59
Vous avez une idée de quel vernis est appliqué ?
Car le cadre me semble vernis plutôt que peint comme on voit clairement les soudo brasures
vib
Messagede 16 à Lier » Jeu 22 Déc 2016 16:56
Juste comme ça , oui il font des cadres Chez Victoire , je roule avec un depuis plus de 2 ans :P .
Ils presque 100 cadres en commandes
C'est un vernis coloré dans la plupart des cas ( il me semble projection d'une poudre colorée puis d'un vernis et cuisson au four )
16 à Lier
Messagede seb@bes » Jeu 22 Déc 2016 21:45
D'après une récente discussion avec Julien, la finition "vernis" va disparaître à cause de problèmes d'oxydation des tubes dans le temps.
Bref en gros ça marche pas si bien que ça, pour que Victoire puisse décider de revenir à des choses plus classiques.
Bien entendu, cela ne s'applique à du stainless steel ;-)
seb@bes
Messagede levacon » Ven 23 Déc 2016 07:41
Normal qu un acier s oxyde juste avec un vernis !!
en 25 ans de metier je le sais depuis longtemps !!
depuis le début en somme :)
jplv
levacon
Messagede vib » Ven 23 Déc 2016 08:39
vib
Messagede sebaudet » Ven 23 Déc 2016 15:48
Et oui jplv quand la réalité de la physique remet en ordre les choses, moi je dis +++++1... et respect pour les artisans avec de la bouteille, et des bons conseils....à écouter même si des fois c'est moins fun !
PS : et ça marche pas que pour les cadres de vélo !
sebaudet
Messagede faber » Sam 24 Déc 2016 09:50
Ah oui ! :shock: C'est bien moche !!
faber
Messagede Doc holliday » Dim 25 Déc 2016 07:56
levacon a écrit:Normal qu un acier s oxyde juste avec un vernis !!
Désolé mais je n'y connais rien en cadre acier. Donc, pourquoi un acier s'oxyde juste avec un vernis et est-ce qu'un cadre acier peint ne s'oxyderai-il pas également sous la peinture sans que cela se voit ?
Messagede levacon » Dim 25 Déc 2016 09:22
Grâce à une couche d aprèt qui l empêche de s oxydé
Un peux comme une voiture !
Ce qu a fait victoire avec sont vernis coloré je l ai fait il y a 22 ans !! Bonjour les retours sur les oxydation !!
JP
jplv
levacon
Messagede domino » Dim 25 Déc 2016 10:13
meme réaction que toi, et ce n'est pas l'explication de JP qui m'éclaire , ou alors la lumiere !! non pas la mienne de lumiere , la lumiere qui oxyde ??
scott addict 5,350 kg
domino
Messagede Doc holliday » Dim 25 Déc 2016 12:18
JP
Merci pour l'explication ;)
Messagede elfuinha » Mar 8 Aoû 2017 10:57
It's Finished for now!!!
http://weightweenies.starbike.com/forum/download/file.php?id=64311&mode=view
http://weightweenies.starbike.com/forum/download/file.php?id=64310&mode=view
Saddle is now a Berk Lunipa 150mm but i don't have pictures.
+-7,0kg
Still missing a powermetter - Quarq or Power2max NG specialized
elfuinha
